0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#5834 04/01/2004 11:29 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I have a rochester single barrel carb and need to connect the throttle cable to the carb. There is not a small block on the throttle linkage similar to the choke cable connection. The choke cable connection is a small block with a hole in it and a set screw. Does the throttle cable attach the same way? Where can I get one of the small connection blocks? As always thanks for the help  | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Just looked at mine and the throttle cable goes down from the top with the housing stopping at the top of the carb and the cable/wire continuing through a little hole in the throttle linkage bar that comes up from the engine block pivot area. Once through this little hole the cable/wire is secured by yes another block similar to the choke setup.
If this confuses the heck out of you, I can alway post a pic later tonight.
Craig
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Sep 2003 Posts: 37 Junior Member | | Junior Member Joined: Sep 2003 Posts: 37 | That would be great if you could post a picture. My truck is also missing some throttle linkage parts and it would be great to see what they're supposed to look like. Thanks! | | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I would appreciate seeing the picture so I can finally attempt to attach the cables. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Gents, Sorry it took so long. Hope the following will help. Craig http://community.webshots.com/photo/127846177/130825413MNkigr
#5839 04/03/2004 11:11 PM | Joined: Oct 2003 Posts: 9 Member | | Member Joined: Oct 2003 Posts: 9 | Hey cmayna Where could I get the bracket that mounts to the carb for the 2 cables?
Friends don't let friends drive F**ds.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Don't really know but I bet if you ask MT (fellow member) that question, he might be able to steer ya in the right direction.
| | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | Thanks for the picture it helps me understand how everything is connected. Where can I get one of the little blocks to secure the throttle cable???? :confused: | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I would think if you took a stroll through a wrecking yard where there are some older Chevy pick ups and older Chevy cars (40's to early 50's), you should be able to find a bracket that attaches the choke cable and throttle cable to the carb. Another place where I have found some older carb parts is a rebuilders shop. One in Fort Worth has old carbs they rebuild and the brackets are on some of those carbs. I had to talk for quite awhile to get them to sell me some parts like that, but finally got what I needed. Also, some looking at the swap meets should turn one up. You may have to buy an old carb core, but having the bracket might be worth $5.00 - $10.00. The little cable stop piece is something you can get at a good hardware store or a lawn mower repair shop. They use cable stops on mowers and edgers. NAPA should also have the cable stops.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | Thanks for the tip. I'll check with NAPA and a lawn mower shop.  | | | | | Joined: Sep 2003 Posts: 37 Junior Member | | Junior Member Joined: Sep 2003 Posts: 37 | Wow! Thanks for the photo, cmayna! | | | | | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | Hey, for you guys that need that bracket deal, our sponsor, American Classic, has it in the used parts section. It was 5 bucks.
51 Chevy 1/2 ton-Restored 46 GMC 1 1/2 ton-Farm Fresh
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Dan51, Thanks for letting these guys know where they can find one. Maybe now I won't worry about one of them removing mine.
cheers
| | | | | Joined: Apr 2013 Posts: 7 New Guy | | New Guy Joined: Apr 2013 Posts: 7 | Hello, I am in the same boat. I can't seem to find a place to connect my dash mounted throttle cable too. The choke cable is done, but where does the throttle cable hool too. Can you send me a picture please.
Thanks,Paully | | |
