3 members (Lostbuthaulinass, Otto Skorzeny, Nick in Manitou), 81 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#58407 03/28/2006 2:10 AM
Junior Member
Junior Member
Howdy everybody,
I just took of my muffler as some of you may know,and by the way it sounds great kinda like a V8 but better, just the way i like it! but anyways my question is now since I can hear the pipes I found out it sputters in 4th maybe in third to but I cant hear it.The only time I really notice it is when im going about 50 or 55 mph down the road.
ANY SOLUTIONS?
#58408 03/28/2006 5:28 AM
Is it worse under load? If it gets worse when you accelerate in low or second,or cruising in 3rd or 4th,it might have a plug wire that's going bad or shorting to a ground somewhere.
Might be worth giving it a set of wires and plugs,maybe points and condensor too,or at least check your settings,points gap,timing,etc.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#58409 03/28/2006 1:51 PM
Junior Member
Junior Member
Thanks Speed,
I think its about time for new wires anyways. I have never changed them. I just Got through putting new plugs points condeser oil and filter. I have never really messed with the timing and dont know how but I can always look in the old shop manual.
#58410 03/28/2006 7:16 PM
I had a noticable miss at idle with new plugs. I pulled them and regapped them all. One had a very narrow gap. That solved my problem--too simple.
