9 members (treegrower, Wayne67vert, 55shaker, Bill Hanlon, moparguy, Phak1, Oswald, 2 invisible), 65 guests, and 1 robot.
Topics128,089
Posts1,056,005
Members48,430
#5834 04/01/2004 11:29 PM
I have a rochester single barrel carb and need to connect the throttle cable to the carb. There is not a small block on the throttle linkage similar to the choke cable connection.
The choke cable connection is a small block with a hole in it and a set screw. Does the throttle cable attach the same way? Where can I get one of the small connection blocks? As always thanks for the help grin
#5835 04/02/2004 4:42 PM
Just looked at mine and the throttle cable goes down from the top with the housing stopping at the top of the carb and the cable/wire continuing through a little hole in the throttle linkage bar that comes up from the engine block pivot area. Once through this little hole the cable/wire is secured by yes another block similar to the choke setup.
If this confuses the heck out of you, I can alway post a pic later tonight.
Craig
Craig
#5836 04/02/2004 4:54 PM
Junior Member
Junior Member
That would be great if you could post a picture. My truck is also missing some throttle linkage parts and it would be great to see what they're supposed to look like. Thanks!
#5837 04/02/2004 5:47 PM
I would appreciate seeing the picture so I can finally attempt to attach the cables.
#5838 04/03/2004 5:06 PM
Gents,
Sorry it took so long. Hope the following will help.
Craig
http://community.webshots.com/photo/127846177/130825413MNkigr
Craig
#5839 04/03/2004 11:11 PM
Hey cmayna
Where could I get the bracket that mounts to the carb for the 2 cables?
Friends don't let friends drive F**ds.
#5840 04/04/2004 2:40 AM
Don't really know but I bet if you ask MT (fellow member) that question, he might be able to steer ya in the right direction.
Craig
#5841 04/04/2004 2:52 AM
Thanks for the picture it helps me understand how everything is connected. Where can I get one of the little blocks to secure the throttle cable???? :confused:
#5842 04/04/2004 5:21 PM
smile
I would think if you took a stroll through a wrecking yard where there are some older Chevy pick ups and older Chevy cars (40's to early 50's), you should be able to find a bracket that attaches the choke cable and throttle cable to the carb.
Another place where I have found some older carb parts is a rebuilders shop. One in Fort Worth has old carbs they rebuild and the brackets are on some of those carbs. I had to talk for quite awhile to get them to sell me some parts like that, but finally got what I needed.
Also, some looking at the swap meets should turn one up. You may have to buy an old carb core, but having the bracket might be worth $5.00 - $10.00.
The little cable stop piece is something you can get at a good hardware store or a lawn mower repair shop. They use cable stops on mowers and edgers. NAPA should also have the cable stops.
#5843 04/04/2004 6:36 PM
Thanks for the tip. I'll check with NAPA and a lawn mower shop. grin
#5844 04/05/2004 3:05 AM
Junior Member
Junior Member
Wow! Thanks for the photo, cmayna!
#5845 04/06/2004 6:25 PM
Hey, for you guys that need that bracket deal, our sponsor, American Classic, has it in the used parts section. It was 5 bucks.
51 Chevy 1/2 ton-Restored
46 GMC 1 1/2 ton-Farm Fresh
#5846 04/06/2004 7:33 PM
Dan51,
Thanks for letting these guys know where they can find one. Maybe now I won't worry about one of them removing mine.
cheers
Craig
Hello, I am in the same boat. I can't seem to find a place to connect my dash mounted throttle cable too.
The choke cable is done, but where does the throttle cable hool too.
Can you send me a picture please.
Thanks,Paully
