4 members (Charles in CA, Shade Baby, Hotrod Lincoln, 46 Texaco), 119 guests, and 3 robots.
Topics128,162
Posts1,056,913
Members48,458
#583451 10/15/2009 12:55 AM
i have a 235 with a roch model b float seems ok and the setting needle is clear, but fuel is running down carb truck runs,of course it is rich not sure were to start i could use some suggestions, thanks trying
Here is a link to the 54 shop manual that has some information about float level adjustment. http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0653.html Don't know what year engine you are working on so hope this helps.
The float level gauge is something easily made. I have had good luck setting the float level at 1-9/32 inch with 1-3/4 inch drop.
I just went through this with my carburetor. In the end replacing the needle and seat, which I trusted, corrected the problem. Your carburetor is flooding. Other causes can be a bent float sticking on the chamber sides or a float that has a hole in it.
1951 1 Ton Completed
thanks will try that,when you look down the carb when it is running it is just pooring in,the float felt fine but will pick up a kit, thanks trying
Riding in the Passing Lane
You probably have a piece of dirt in the needle & seat. Make sure you have a fuel filter somwhereclose to the carb.
1972 Chevy c10 Cheyenne Super
