8 members (Ridgeback, GMCJammer51, Biermann, Danielbolt, sron48, GIJOE298, Phak1, DadsFirstPickup),
111
Mod | | | Forums66 Topics128,154 Posts1,056,835 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | i have a 235 with a roch model b float seems ok and the setting needle is clear, but fuel is running down carb truck runs,of course it is rich not sure were to start i could use some suggestions, thanks trying | | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Here is a link to the 54 shop manual that has some information about float level adjustment. http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0653.html Don't know what year engine you are working on so hope this helps. The float level gauge is something easily made. I have had good luck setting the float level at 1-9/32 inch with 1-3/4 inch drop. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just went through this with my carburetor. In the end replacing the needle and seat, which I trusted, corrected the problem. Your carburetor is flooding. Other causes can be a bent float sticking on the chamber sides or a float that has a hole in it. | | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | thanks will try that,when you look down the carb when it is running it is just pooring in,the float felt fine but will pick up a kit, thanks trying | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You probably have a piece of dirt in the needle & seat. Make sure you have a fuel filter somwhereclose to the carb. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
