6 members (46 Texaco, Shade Baby, BarryP, Oswald, Robert Crandall, dt235sd), 92 guests, and 2 robots.
Topics128,162
Posts1,056,910
Members48,458
I don't know if the HEI cap for a six will fit a 8 cylinder HEI distributor. If it will ...
SOMEWHERE I read a post about modifing an HEI to fit into a 270 L6. The boss that rests on the engine block and limits how far inside the shaft goes into the engine was removed and a ring of some kind was installed to set the depth of the gear, What keeps the HEI shaft centered in the hole? Can a 8 cyl. HEL be used on my 270 L 6?
1999 GMC Yukon
1957 GMC 100 Panel
You may want to contact Langdons. They have an HEI that's already setup for use in the inline 6. Theirs is modified from the 4.3 V6, I beleive.
Bill Burmeister
How would I contact them please?
Also are the V-8 and V-6 HEI's the same only with different caps and innerds? In other words can I adapt an HEI (8Cyl)I have on hand to work on my 270?
1999 GMC Yukon
1957 GMC 100 Panel
A v-8 dist. will not work on a 6 cyl.engine. Langdons stovebolt.com, Tom will help you out with whatever you need. He knows all there is to know about inline 6, give him a call.
Tommy
59 apache 1/2t
261 short stepside
I have converted a V-8 distributor housing to work on an inline 6, but it's a very complicated procedure that I wouldn't reccomend unless you're a master machinist. It involves fabricating bushings and cutting the housing to the proper length, and changing the reluctor and pickup assembly out for a 6-cylinder unit, etc. It's also necessary to machine the original locating shoulder off, and fabricating a mounting bracket to position the housing at the right height. Then you need to make a new shaft, and braze a mechanical advance assembly on at the right location. I've been at the auto repair trade for 50+ years, including a lot of round track racing, and adapting a V-8 distributor to a six is a challenge for me.
1 Offline
sent you a pm! you don't use a V8 dist. you use a 6cyl. one. easy conversion. thumbs_up
