2 members (Woodcmiami, baldeagle), 93 guests, and 10 robots.
Topics128,014
Posts1,055,324
Members48,419
#58336 03/26/2006 7:04 AM
OK,
I've done a search, and I have checked and done the following...
Cleaned points, disconnected condenser, replaced coil with a known good coil, bypassed ballast resistor, checked plugs, wires, cap and rotor.
The engine cranks over fine, plenty of gas, spark at plug is very weak. I even hooked up a fully charged battery directly to the distributor, and it still would not fire. I have verifed 12.86 volts from the battery all the way to the points, and still a very weak spark.
My dad tonight mentioned on the phone to check the ground to the engine, to make sure there is not a ground issue.
Does any one have any other ideas, short of ordering up one of Langdons electronic distributors for my 235? Or maybe do the Pertronics? Right now I just want to be able to move it under power, and she refuses to fire up...
ANy help would be greatly appreciated.
Garry K
Garry K in Pac Nor West
1948 Chevy PU 235 SM420 4 spd
1932 **** B pu
1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#58337 03/26/2006 7:32 AM
3B Offline
Hy Garry K, Is the condenser still disconnected? The condenser helps the field colapse quicker giving a better spark, you must have a good condenser in the circuit or your points will burn. Put in a known good condenser, or a new one and try to start it again.
#58338 03/26/2006 11:03 PM
Thanks 3B
I'll give it a try.
Garry
1932 **** B pu
#58339 03/27/2006 3:42 PM
Well I recharged the battery, and put another battery in parallel, replaced the condesor, and gave it another try, and got her to fire, a little more finess, and she was running, found a few more things to work one... Choke cable is rusty again, so need to pull it out, and oil it up again... and found a few new "friends" moved into the cab while I was out to sea with the USN... so now I need to find where they were living and make sure I got them all out...
Thanks again 3B,
Garry
1932 **** B pu
#58340 03/27/2006 4:58 PM
3B Offline
Hy Garry, good to hear, keep on trucking with your reannimation project.
#58341 03/28/2006 2:03 PM
I had the same problem with my 53 216 pickup I replaced the coil and corected the problem.Hope it works for you.Beaver
