| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 24 New Guy | | New Guy Joined: Oct 2009 Posts: 24 | Has anyone put a newer (1982) style chevy truck rear end in a 39-46 truck? I think they're probably a lot wider, but i have the torque tube rear end in there now, and i want to switch it over to open driveshaft stuff so i can put my newer L6 and 3 spd in it. I already have a '82 donor truck that i can rob parts off of for the swap, will it work? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Jake, you will find that the 82 rear is giong to be way too wide for your 39-46. There are others on this forum that know more about this than I do, but some have used the rear end out of a 4X4 Blazer. This gives you the six stud wheels. The other option, which is what I did, is to find the center pimpkin out of a 55-59 1/2 ton. It will bolt right up to the 46 axel housing giving you an open drive line and a 3.90 rear end. This combo works well with my T5. Hope this helps George | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is 1955-62 1/2 ton pumpkin that will work.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | hey 46 - i'm close to what you're doing. what's your 5th gear ratio, what size tires, and what's it taching @65mph? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Some guys have used a Chevy S-10 rear end, for an OLD early 30s vehicle use the narrow 2WD S-10, for your truck the 4WD S-10 should work. These are 5 lug however.
In my 46 besides the original diff, I've used a passenger car torque tube, a 57 Chev pickup rear and now a 66 chevy pickup rear end. So you see there are many options, attempting to keep the 6 lugs will limit your choices a lot.
I chose not to keep my original rear end because of the crappy HUCK brakes it used. Now I have brakes all the way around that I can actually get parts for anywhere.
| | | | | Joined: Oct 2009 Posts: 24 New Guy | | New Guy Joined: Oct 2009 Posts: 24 | I thought it was too wide, i don't care if it's 5 or 6 lug, turns out that my uncle put a nova rear end in his '46, and it fit like a glove he said. Even the spring perches fit i guess. I think i have one of those so i might try that. First thing i have to do is get the front brakes put back together though. I'm going to adapt discs to it i think. | | |
