3 members (GIJOE298, Gray_Ghost, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,078
Posts1,056,056
Members48,433
I've been honing my rear wheel cylinders for my 4400 big bolt. I have only one side apart right now. I have two pistons that just have a smooth taper in them where the pushrod goes, and two that have a step where the taper begins. Is this normal? Does it matter where I put them? Thanks for any help. Jim
3B Offline
Hy ChetMan, are you saying that one set of pistons use ring type cups, and the other set take the regular flat cups. I can't invision what you're trying to describe, any chance of a picture?
Shop Shark,
I don't have a picture, but I'll try to describe it better. The little pushrods that have a fork on them...that slip over the brake shoe and the other end goes into a little dished-out area of the wheel cylinder's piston. Follow where I am this time? That dished out area that the pushrod goes into is the area I am talking about. Two of my pistons dished out places are smooth to the edge of the piston's diameter, while two go up to a little 1/8" shoulder around the edge of the piston. Just can't think of a reason why it would make a difference...
3B Offline
Hy ChetMan, thanks for the description, I don't think it will matter as long as the brake shoes will come all the way back to their anchor points, hope that helps.
I would agree with 3B. I would think that at some time, they were replaced or the pistons were repaced and the piston design was slightly different between suppliers.
1951 1 Ton Completed
