2 members (carbking, RLB),
157
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 116 | I've been honing my rear wheel cylinders for my 4400 big bolt. I have only one side apart right now. I have two pistons that just have a smooth taper in them where the pushrod goes, and two that have a step where the taper begins. Is this normal? Does it matter where I put them? Thanks for any help. Jim | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ChetMan, are you saying that one set of pistons use ring type cups, and the other set take the regular flat cups. I can't invision what you're trying to describe, any chance of a picture? | | | | | Joined: Aug 2008 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 116 | Shop Shark, I don't have a picture, but I'll try to describe it better. The little pushrods that have a fork on them...that slip over the brake shoe and the other end goes into a little dished-out area of the wheel cylinder's piston. Follow where I am this time? That dished out area that the pushrod goes into is the area I am talking about. Two of my pistons dished out places are smooth to the edge of the piston's diameter, while two go up to a little 1/8" shoulder around the edge of the piston. Just can't think of a reason why it would make a difference... | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ChetMan, thanks for the description, I don't think it will matter as long as the brake shoes will come all the way back to their anchor points, hope that helps. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would agree with 3B. I would think that at some time, they were replaced or the pistons were repaced and the piston design was slightly different between suppliers. | | |
