| | | Forums66 Topics128,046 Posts1,055,618 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58308 03/25/2006 8:11 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | My newley restored 53 chevy pickup throttle cable workes it's way out while I'm driving it.How do I adjust it so it doesn't work out and that it stays in place when I want it to? Thanks Beaver 53 @ [email protected] | | |
#58309 03/25/2006 10:01 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Hey Beaver, welcome to the site from a neighbor. There's a whole mess of us North Texas guys on the site, informally "The Texas Connection". We get together at swap meets and shows. You're welcome to join us.
If your throttle cable is connected properly I see no way it could work it's way out. Maybe it is not connected properly. The cable should slide through a hole in one of the linkage rods with no binding. | | |
#58310 03/25/2006 10:41 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Without looking at it my first guess would be that your throttle linkage is rubbing/pushing on the end of your hand throttle wire. When you press the foot throttle it's slowly pushing the hand throttle wire too. I would watch the hand throttle wire as the throttle linkage is activated to see if that's where the problem is. If that turns out to be the problem the fix should be obvious. Good Luck.
#58311 03/25/2006 10:57 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Try putting a little grease on the cable where the trottle linkage slides up & down on it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
