6 members (Ridgeback, mick53, MickeyP, Rusted Nut, Steelonsteel, Ol'55), 52 guests, and 2 robots.
Topics128,043
Posts1,055,612
#58308 03/25/2006 8:11 PM
My newley restored 53 chevy pickup throttle cable workes it's way out while I'm driving it.How do I adjust it so it doesn't work out and that it stays in place when I want it to? Thanks Beaver 53 @ [email protected]
#58309 03/25/2006 10:01 PM
Hey Beaver, welcome to the site from a neighbor. There's a whole mess of us North Texas guys on the site, informally "The Texas Connection". We get together at swap meets and shows. You're welcome to join us.
If your throttle cable is connected properly I see no way it could work it's way out. Maybe it is not connected properly. The cable should slide through a hole in one of the linkage rods with no binding.
#58310 03/25/2006 10:41 PM
Ex Hall Monitor
Ex Hall Monitor
Without looking at it my first guess would be that your throttle linkage is rubbing/pushing on the end of your hand throttle wire. When you press the foot throttle it's slowly pushing the hand throttle wire too. I would watch the hand throttle wire as the throttle linkage is activated to see if that's where the problem is. If that turns out to be the problem the fix should be obvious. Good Luck.
#58311 03/25/2006 10:57 PM
Riding in the Passing Lane
Try putting a little grease on the cable where the trottle linkage slides up & down on it.
1972 Chevy c10 Cheyenne Super
