5 members (Rich'sToys, dt235sd, baldeagle, Bill Hanlon, Barry Martak), 49 guests, and 6 robots.
Topics128,179
Posts1,057,157
Members48,464
#58271 03/24/2006 7:49 PM
Junior Member
Junior Member
Hey guys will all the disc brakes and power steering and brake boster fit on a 66 from a 74 ? what about rearend? just wanted to know i have a free 74 given to me with a good driveline just wanted to know if anything will interchange...thanks Terry
#58272 03/24/2006 9:08 PM
the rear will fit but you must move perches, the whole front crossmember will almost bolt on-you may need to ream a hole or two or drill one or two. Powerbooster will fit, just drill an extra hole or two, mine all came from a 1980 C10,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#58273 03/25/2006 6:04 AM
Junior Member
Junior Member
thanks brian that helps i just got a free 74 and the only thing good is the driveline and it has no motor but a 350 tranny i can swap someone something for...Terry
#58274 04/21/2006 4:32 AM
I'm just about to do the same thing, but mine is a '77 3/4 ton 4x4 drivetrain going into a '64 shortbed. Any experience in any hang ups that are gong to occur?
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1964 c-60 dump truck
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
#58275 04/21/2006 12:41 PM
Junior Member
Junior Member
I've got that set up under my 66 c20. the only thing you will run in to is mounting the steering box and the linkage. I think I ended up with the 66 center link and idler arm with the 74 tierods. The steering joint for the input shaft is differant too.
Good luck with it.
Raycr
