3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58271 03/24/2006 7:49 PM | Joined: Feb 2006 Posts: 28 Junior Member | | Junior Member Joined: Feb 2006 Posts: 28 | Hey guys will all the disc brakes and power steering and brake boster fit on a 66 from a 74 ? what about rearend? just wanted to know i have a free 74 given to me with a good driveline just wanted to know if anything will interchange...thanks Terry | | |
#58272 03/24/2006 9:08 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | the rear will fit but you must move perches, the whole front crossmember will almost bolt on-you may need to ream a hole or two or drill one or two. Powerbooster will fit, just drill an extra hole or two, mine all came from a 1980 C10,,brian | | |
#58273 03/25/2006 6:04 AM | Joined: Feb 2006 Posts: 28 Junior Member | | Junior Member Joined: Feb 2006 Posts: 28 | thanks brian that helps i just got a free 74 and the only thing good is the driveline and it has no motor but a 350 tranny i can swap someone something for...Terry | | |
#58274 04/21/2006 4:32 AM | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | I'm just about to do the same thing, but mine is a '77 3/4 ton 4x4 drivetrain going into a '64 shortbed. Any experience in any hang ups that are gong to occur?
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Elanor Roosevelt
1966 c-10 stepside 1966 c-10 fleetside 1964 c-10 fleetside 1964 c-10 short bed 1964 c-30 flat bed 1964 c-60 dump truck 1968 Impala 1969 Nova 1971 Nova 1975 LUV 1976 C-30 1977 K-20 1966 SS El Camino
#58275 04/21/2006 12:41 PM | Joined: Apr 2006 Posts: 7 Junior Member | | Junior Member Joined: Apr 2006 Posts: 7 | I've got that set up under my 66 c20. the only thing you will run in to is mounting the steering box and the linkage. I think I ended up with the 66 center link and idler arm with the 74 tierods. The steering joint for the input shaft is differant too. Good luck with it. Raycr | | |
