1 members (1 invisible),
105
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | Hey all, On my almost big bolt 3800(the dually with hydraulic dump bed)I need to rebuild my side fences-
The metal frames are nice- but the are beat up and have about 12000 rivets holding the old side wood on. Because I do not plan on hauling grain I thought about building replacements with wood uprights rater than metal- anyone been down this road before?
The most this will haul of bulk will be firewood- and I plan to reinstall the chain that holds the two sides together in the middle of the bed.
Thanks, Sam | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Haven't been down the road yet but I'm going to build what would resemble factory style stake racks on my 1954 3809.
Bruce | | | | | Joined: Aug 2001 Posts: 3,603 Moderator | | Moderator Joined: Aug 2001 Posts: 3,603 | Another big bolt saved by an old Blue Oval.
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | I am an equal opportunity offender- I like most old equipment- reminds us where we came from. As for the Particular blue oval of mine- It has saved many a piece of history. | | | | | Joined: Jul 2004 Posts: 2,988 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,988 | Many of the old grain boxes were made with wood stakes. Then it was just tongue and groove boards bolted on with carriage bolts. | | | | | Joined: May 2008 Posts: 114 Shop Shark | | Shop Shark Joined: May 2008 Posts: 114 | You may need to enlarge the bed pockets if a 2x4 will not fit. I used pressure treated 2x4's carriage bolted to two 2x10's on the side on my 12 foot dump bed and have not had any problems with loads. My sides are much shorter than yours and would need stronger uprights if higher. In the future I plan on having higher sides and I'll use steel uprights then. James | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Just FWIW the correct name of the parts is Stake Sides. Maybe I'm too close to the subject as I have never heard them called "fences" in my 43 years in the business. I got a laugh from that so Thanks. Needed a laugh today.
The factory built stakes were built with rivets and generally had oak posts and slats. Some used pine but the clear lumber became so expensive and difficult to get in the 80's that all of them went to steel stakesides only being offered. No one now offers wood sets that I'm aware of. Stakes were generally 1x 6 planks. Post size depended upon the manufacturer but common today is 1.5"x 3.5". I prefer tapered posts/pockets so they stay put.
Great looking truck. I had a 66' just like it in the 70's with 305 V6 and 4 & 2 speed. | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | Stake Sides I will remember that. The holes are probably 1.5 X 3.5 or 4(My house and the barn are not really close to each other.
I like the idea of the taper.
Thanks for the help. Sam | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | Hello Sam, I have only done the cab side so far. I will do the rest soon. Anyway,I'm following the plans that you can see here http://www.ag.ndsu.nodak.edu/abeng/plans/6192.pdfIts raining in Fairfax California Should I buy that fire truck? Chris | | | | | Joined: Jul 2004 Posts: 2,988 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,988 | Should I buy that fire truck?
Chris Not sure which fire truck you're talking about, but.........yes!  | | |
