| | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58267 03/24/2006 7:40 PM | Joined: Oct 2005 Posts: 34 Junior Member | | Junior Member Joined: Oct 2005 Posts: 34 | I have a rear end for a 1952 with torque tube. I would like to change it to an open drive shaft. I heard there are conversion kits for that type of modification, is that so and were would you find one? (I will use a trany that does not use a torque tube set up.) Or is my only option to use a different rear?
Frank 1949 Chevy 3800 1929 Chevy International
#58268 03/24/2006 8:01 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | "Or is my only option to use a different rear?"
Yes. | | |
#58269 03/24/2006 8:40 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I think you can swap a 55-62 open drive line center section into your housing and still use the original axles and brakes. I've seen it talked about here before. I believe you would also have to weld your spring mounts so they don't pivot anymore. I'm sure somebody that has done it can give you some more info. Or try doing a search on center section swap or similar terms. | | |
#58270 03/24/2006 9:11 PM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | I've done what Goshtrider describes. The center bolts in but you need to do something about the pivot on the rear, I welded them up. Another option would be to cut off the pivots and weld on traditional sping perch. There is a kit to weld rears into AD tucks that would work also.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
