5 members (74cheyennesuper, Ponchogl, NJC, baldeagle, Bill Hanlon), 63 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#582005 10/10/2009 5:53 AM
Do you prime bare metal before using any bondo?
"Happiness equals reality minus expectations" - Tom Magliozzi
Jim Bow #582015 10/10/2009 6:49 AM
You can apply plastic filler (bondo) over primer but bare metal is best. I usually apply a couple coats of Epoxy Primer on bare metal and plastic filler over that.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
Jim Bow #582192 10/10/2009 11:21 PM
Ex Hall Monitor
Ex Hall Monitor
The rougher the metal the better. It gives the plastic more "tooth". You can put plastic over primer or paint but keep in mind that while it will probably stick to the primer or paint, IF the primer or paint looses adhesion and peals your plastic will peal right along with it. That's why it's recommended putting in over bare metal.
Tiny #582271 10/11/2009 3:48 AM
You might find this interesting. http://www.autobodystore.com/filler_&_epoxy.shtml
Eileen #582301 10/11/2009 6:47 AM
That kinda answers that one for me... Very interesting! grin
More pix on Flickr.
jockbolter50 #582312 10/11/2009 7:51 AM
Good Post Eileen!
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #582342 10/11/2009 2:07 PM
Pointless unless you plan to wreck your truck and maintain maximum amount of plastic filler after the wreck. Since there is no molecular bond between the filler and the base material any bond will fail.
Want a filler that will not separate from the base material, use body solder.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #582626 10/12/2009 10:21 AM
There ya go, I agree with ya 100% Woody. In an area that is highly stressed, for instance where the running board and rear fender are bolted together, I would only use lead. Just try to get the "lead out" if it's been properly preped and applied.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
