1 members (Millenimech),
118
Mod | | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Hi guys, I need to know the measurements of the door window glass of my 1952 chevy truck. I don´t have the facility to buy them in a local store, I have to make then with tempered glass. please, anybody can help me? Alfonso | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Alfonso, I have a glass sitting in my shop that I can measure but it will be tomorrow. If no one else gives the dimensions I can get them...... If necessary I could draw a pattern for you if needed.
EDIT: I should have mentioned that the glass is out of my 52 Panel which is the same as your truck.
| | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Ooh, thanks a lot, I´ll be waiting. Alfonso | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Alfonso, I measure the glass I have and it measures 16 3/8" High and 18 1/4" Wide.
I'm sure you know on top corner is rounded pretty good and the other top corner is rounded a little bit.
Hope this helps you. If need I could gets some copy paper and draw trace it off. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Obviously the glass is not totally square,so IMO it would be much better as Alvin said, to trace a pattern and use that instead. I did this and had mine made up in 5mm Tempered green tinted glass. I realise your glass is the smaller one,without the frame. Shouldn't cost a bunch either!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Jock, around here I was quoted 150 for the two side windows and the wing vents. I did a little haggling and got the tinted side windows/wing vents for 100 bucks..... Just in case anyone was wondering!! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Alvin...Was that for tempered? If so,for having them cut and toughened(as we call it here)$100 is not too bad. It's not what you know ,it's who you know! I managed to get all the glass,including having the side and rear glass cut and tempered for less than $150. That included a half sheet of 6.4mm Laminated green tinted glass for cutting my front windshields.(I'd just better not screw up!)
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | yep, and your right. Its who you know.(saved me $50 bucks and they still made money!) I had such a good deal going I wanted to get the glass for the front but I had purchased the windshield from a fellow who gave up on his project. cost me $40 (both pieces) The glass is still in the box and had never been taken out. I may offer them up for sale so I can get some tinted ones?
