4 members (Shaffer's1950, artinva, Chip O, 1 invisible), 124 guests, and 3 robots.
Topics128,072
Posts1,055,903
Members48,429
#581164 10/07/2009 2:17 AM
unbolted the beast(gas tank)and found out it was arch welded to the back window panel. Do I drill out the welds carefully and pry it off, or just grind the weld spots? Putting a new tank under the bed. Thanks Stovebolt Nation.. WisApache
If the tank is junk fill it with water and you can do anything with it. Vapor burns/explodes elimnate the vapor area and it won't do anything. Drain it when you are done. The most dangerous tank is a nearly empty one with lots of vapor area by volume.
Someone WELDED the gas tank to the body? Good Lord, what next?!
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
