| | | Forums66 Topics128,060 Posts1,055,839 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 11 New Guy | | New Guy Joined: Sep 2009 Posts: 11 | unbolted the beast(gas tank)and found out it was arch welded to the back window panel. Do I drill out the welds carefully and pry it off, or just grind the weld spots? Putting a new tank under the bed. Thanks Stovebolt Nation.. WisApache | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If the tank is junk fill it with water and you can do anything with it. Vapor burns/explodes elimnate the vapor area and it won't do anything. Drain it when you are done. The most dangerous tank is a nearly empty one with lots of vapor area by volume. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Someone WELDED the gas tank to the body? Good Lord, what next?! | | |
