| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58083 03/21/2006 5:41 AM | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | Just wanted to get some input on an idea I have... the project truck is a 65 Chevy 4x4 C10... donor/parts truck is 79 Chevy 2wd 3/4... in the very near future (as in less than 2 weeks) will be doing an engine & tranny swap... pulling 350 from the 79 and replacing 283 from the 65 (redoing 283 at later point down the road).
My thinking is that I will also be able to "convert" some other parts over to the 65 with little or no problems... will any of the follow ideas be okay to use on the 65 and if so how much difficulty will it be...
1. power steering (350 is already set up to run it anyways) 2. A/C (again the 350 is already set up) 3. disc brakes 4. any wiring harnesses
Just thinking out loud here I guess but wanted to get some feedback on any ideas you might have.
Boogity, Boogity, Boogity Let's go racin boys. Drive fast, turn left. GO #20.
Real trucks where bowties.
#58084 03/21/2006 3:23 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | since your parts truck is 2wd the brakes & steering are totally different..brian | | |
#58085 03/21/2006 10:38 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Is the 65 a C10, which means 2wd, or is it a K10 which means 4X4? Either way, you're trying to mix 1/2 ton parts with 3/4 ton parts. They're not easily interchangable or desired that way, Scott | | |
#58086 03/21/2006 10:46 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you use all the pulleys & brackets with the 79 engine you will have the steering pump & a/c comp. all mounted. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#58087 03/23/2006 3:06 PM | Joined: Mar 2006 Posts: 3 Junior Member | | Junior Member Joined: Mar 2006 Posts: 3 | I just completed an engine - transmission install in my 1965 K10 4X4 fleetside long bed. I did the same thing you are trying to do by replacing the 283 with a 350.
I drove race cars for two decades, so I had my engine builder throw together a little 400 hp 350 engine. My '65 was missing the front crossmember, so we fabricated a crossmember that allowed the engine to mount and the headers to go down through the frame rails. However, my 65 does not have power steering or power brakes and I did not choose to install them.
You'll also need to be aware that the crossmember for the transmission mounts under the bell housing and not the rear transmission mount that is likely to be on your transmission from the '79 donor truck. I used an old toploader 4 speed transmission that was able utilize the front mounted transmission crossmember.
I DID pull the front drive axle out of the '65 and replaced it with a front drive axle from a late 80's K5 Blazer. Had to remount the spring perches and shock mounts, but other than that, it was pretty easy. I can send you photos if you think it might help. | | |
#58088 03/23/2006 4:11 PM | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | Thanks guys for the info... looks like I have some checking to do before I proceed... don't want to pull parts off the donor that won't fit the 65.
I am almost certain the chrome piece in front of the doors says its a C10... but definitely gonna double check first... hoping I don't have a mess on my hands but who knows... will update you on what I find.
If you have any other ideas to pass along I'll be glad to listen to those as well.
