| | | Forums66 Topics128,113 Posts1,056,580 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | can someone tell me what i can use for example napa part number or upgrade i could use to replace my master cyliner under the floorboard, could not find any post or im not looking right, any comments welcome. something simple, i thought 129 was a little pricey. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Napa has no listing, but Auto Zone shows a listing for a rebuild kit for $23.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Rock auto still lists them. They have a Dorman and a Raybestos with 1 1/8" bore. Almost everyone has rebuild kits, but unless you have a good hone to actually remove material to get rid of all the pits, the kit will most likely fail. I use an Ammco hone that works like an engine cylinder hone. I use honing oil just like I would honing a cylinder. I then follow up with a dingleberry hone instead of cross hatching. | | |
