Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Otto Skorzeny, cmayna, rick46ia, Steelonsteel), 63 guests, and 2 robots.
Topics128,006
Posts1,055,271
Members48,418
#579813 10/02/2009 1:58 PM
To make a long story short, can anybody tell what the side adjustment under the main cap in the rear end or called. I was trying to set the ring and pinion gear yesterday only to find the side adjustment caps or stripped. 1953 3100 216 engine orginial rear end.
Charlie
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Charley #579845 10/02/2009 3:33 PM
3B Offline
Hy Charley, those large "nuts" are called the differential bearing adjusting nuts, be sure to check the threads in the housing and caps, if those threads are stripped then you must replace the housing/cap assembly, as they are machined as a unit, hope that helps
3B #579850 10/02/2009 3:58 PM
Thanks Shop Shark,
Where can I get a set of these adjusting nuts? NAPA, AutoZone.
1953 5 Window
2006 Chevy Colarado
