3 members (Tronman, Gib70, dt235sd), 126 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#574583 09/15/2009 9:22 PM
I have started replacing my floors. I noticed that the stampings are deeper in the original floor than they are in some after market floors. Is there any guide lines concerning stamping depths? Specifically how deep they should be? I mean, they are clearly there, just shallow, like an 1/8th of an inch or so.
GMCAMARO #574605 09/15/2009 10:47 PM
Y
Y Offline
Not much you can do about the re-pop parts, most of them come from one supplier. In most cases the floor will be covered with insulation/rubber mats/carpet, ect.
Yakimabowtie #574784 09/16/2009 2:00 PM
I understood that, I was curious if there are any judging standards for this sort of thing?
GMCAMARO #578767 09/29/2009 4:18 AM
GMCAMARO
Any Pics of your project?
would love to see them..
loadmaster47
Loadmaster47 #579359 10/01/2009 3:09 AM
Some of the stampings that were made back in the 60's and 70's were closer to the original. I search eBay quite regularly for NOS patch panels and it is surprising how many appear. I like the old made in USA panels better better than the imports because they are more similar to the parent metal and therefor weld easier and I just don't like imported reproductions. I have bought some NOS panels from this guy http://www.surplussupplyco.com/catalog.htm He also sells imports, but he has a lot of NOS stashed away.
crenwelge #579433 10/01/2009 11:30 AM
Find your local sheet metal guy that does generator enclosures and products like that. He will most likely have a turret punch that he is using and can stamp out panels with beads. You may pay a bit for them, however it is an option. (plus you can get them out of 18 gauge or 16 gauge)
GMCAMARO #579454 10/01/2009 1:35 PM
Ex Hall Monitor
Ex Hall Monitor
Probably need to check over at the VCCA site. They have judged events and it's an excellent resource for "correct" restoration information.
