2 members (Gdads51, 3B), 116 guests, and 3 robots.
Topics128,195
Posts1,057,379
Members48,469
#575673 09/19/2009 3:01 AM
Can anyone tell me if a set of Hooker Headers Part # 2603 will fit on a '65 230 cu. in. Chevy 6 banger? The part # isn't in their current book. Help !!! Thanks
Bayoucitybomber #575787 09/19/2009 2:27 PM
Do you have any pics of them?
Larry
I don't own a vehicle that isn't old enough to drink.
Bayoucitybomber #579070 09/30/2009 6:20 AM
Go here and read what it says I think it will help you.And with the amount of room I think they would work just have to email him
Bob
http://www.jalopyjournal.com/forum/showthread.php?t=398674
wojo #579072 09/30/2009 6:51 AM
Maybe it's just me, but those in the pics look like they'd fit up to the passenger side of the head, not the driver's side.
1947 Chevy 6400 Wrecker
Old Stovebolts don't leak oil
They just mark their territory
Willy McCoy #579128 09/30/2009 3:17 PM
Those headers are correct for an integral head 84-89(?). They will not fit an earlier head without major modification.
For the earlier heads there are two styles, passenger and truck, or manual and auto trans. The difference being one will not clear the 'Z' bar and the other will.
Larry
Bayoucitybomber #579166 09/30/2009 5:41 PM
I had Hooker headers on my'65 230 and had them removed due to poor fuel consumption. The original intake manifold is bolted to the exhaust manifold to heat the fuel for this side-draft configuration. The single barrel carb would not function properly without the heat, so I removed the headers and it works much better. Just a thought for consideration before you invest the money...
MDL
PcolaMike #579179 09/30/2009 6:29 PM
Heating the intake is a definite consideration, though the climate you are in is also a factor.
Stovebolt makes a box to bolt under the intake where the exhaust bolted. The box is then plumbed into the cooling system to provide heat to the intake.
Larry
