1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | I just bought another set of gauges for my '58 GMC. The gauges are purportedly from a '56. I notice that on the back of the fuel and temperature gauge are what look like factory resistors or voltage reducers. I don't remember seeing these on my '58 gauges. Anybody know what the story is? | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | '55 for sure and maybe '56? GMC small trucks were still 6V.
On the bigger trucks, that were 12V systems, the factory used the same 6v gauges by installing the resistors.
I was surprised when I got my '55 GMC home and discovered it had been (poorly) converted to 12V.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | According to books, 55 was 12 volt, but every one I have ever seen is still 6 volt except for some of the larger trucks. And yes the factory put resistors on the first 12 volt gauges. I have a 58-59 parts truck. I can look at the back of the gauges. But the ones with the resistors will work for 12 volts. | | |
