7 members (Donf, Goach2, Hanks custodian, rfs56trk, Rusted Nut, Bill Hanlon, 1 invisible),
56
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 18 New Guy | | New Guy Joined: May 2009 Posts: 18 | I have a 53 3100 with the stock rear end (4:11). Looking for adivce on changing out the rear end gear to the 3:55. Pros/Cons.... | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | 3.55 rears will take a lot away from your acceleration at highway speed. At highway speed it will do almost do nothing when you step on the gas. With a stock transmission, there is too big a gap to drop down a gear which will lead you wanting a close ratio 4 speed. This makes a nice cruiser. However, if you have faster gears, you will have less engine braking and you should consider upgrading the braking system. If you are going to be going faster, your steering needs to be in top shape. 3.55's are only a starting point. It can get to be a $3k or $4k deal. I personally don't care for anything less than a 270 GMC or better yet a 302 in front of 3.55 rears, but that adds to the tab also. | | | | | Joined: May 2009 Posts: 18 New Guy | | New Guy Joined: May 2009 Posts: 18 | Yes it does add to the tab... I am not looking for speed but just to lower the RPM's on the stock 216 at 50-60 MPH. The 216 is strong but I just don't know what is to much and for how long. I want to drive my truck to some shows that are about a 45 mile drive on the highway to I just don't want to kill the motor. And yes I don't want to spend a fortune right now. So is that a GO or NO GO... Thanks! | | | | | Joined: Nov 2008 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 65 | You might check out Gear Vendors or Ranger overdrives. They're not cheap either, but they should give you the best of both worlds when it comes to power or speed. | | | | | Joined: May 2009 Posts: 18 New Guy | | New Guy Joined: May 2009 Posts: 18 | Has anyone done this and like/dislike the results? Please let me know?
| | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | As long as your engine is full of oil and you have a good radiator full of coolant, you are not going to hurt a 216 at 50 or 60. Back in the 50's they were usually driven at that speed if the road allowed it. If you are afraid of engine speed, I would invest a few bucks in dropping the pan and plastigauging the babbits and making sure the dippers are in place. If your babbits are good and they get oil, don't worry about it. You will get accustomed to the fan, and valve train noise. Remember there isn't much between you and the engine on these old things. In fact unless you have replaced grommets, there are several places you can see the engine from inside the cab. | | | | | Joined: May 2009 Posts: 18 New Guy | | New Guy Joined: May 2009 Posts: 18 | Yes the cab does have a few holes doesn't it... | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | In reality there is not enough power up front to handle a 3.55 gear in the back. Off the line you would be under powered you'd think the engine was a 4 banger. What these old trucks need is more gears like a box with the normal low gears so you can accelerate but then have an overdrive so the RPM's can be brought down once you get to highway speeds. I say this cause I have a 1 ton diesel,with a 5 speed and it it fine in all the gears but lacks the 6th gear to bring down the R's at highway speeds. If I was to change the rear gear to bring down R's I would loose the power I need in the lower gears. Guess that's why new stuff has 6 speed trans in them ! Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Jan 2009 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 106 | If you inquire through the Stovebolt you may find someone in or near Orlando who has installed 3.55 gears with a 216 you could test drive. You could also talk to Patrick"s in Arizona who are the only ones I know of at this time who are having 3.55 AD gears manufactured. Jim Carter sells Patrick's 3.55 gears and is very helpful.
Stovebolts are good for the heart
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Hey jgwill26, I put a set of 3.55's in my '53 half ton. They came from Patrick's and I had the machine shop put them in for me. He liked the instructions that came with the gears. The truck is not on the road yet, can't say how they will work out. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 1953 Panel, did Patrick's supply the spider gears for you? There was a post a while ago that stated that they supplied them.
Fred | | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | I changed my stock 411 (1957 3200) to a 339 with ring and pinion gears from Yukon Gears out of California | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Has anyone done this and like/dislike the results? Please let me know? I changed mine to 3:35 (from Patricks). Went from about 3300 to 2800 at 70 MPH and am very happy with it. Running a 350 and a saginaw 4 speed. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Whether 3:55 gears are for you depends on how you plan to use your truck. If you plan on going on long drives, or drive at highway speeds, then go for it.
I put these beauties in my truck, and its one of the best upgrades I have ever done. I have installed several sets of these in my and my buddies truck.
If you check out my Webshots page, there is an album dedicated to this swap.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: May 2009 Posts: 18 New Guy | | New Guy Joined: May 2009 Posts: 18 | | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Fred, Patrick's did not supply the spider gears, I got lucky and found a very good set locally for nothing. Leo | | |
