| | | Forums66 Topics128,034 Posts1,055,539 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Going thru the logistics of putting an S10 T-5 transmission in my 55 2nd with a 235. Read all there is to read regarding the swap and have hit a wall with the flywheel. Picked up what I thought was a small block flywheel this afternoon and turns out, according to the casting # 3789733, a big block version. Research indicates that there was no difference in the small to big block flywheels except for some big block 400`s. Matching it up with a 235 flywheel I got with a spare engine, it is off on the bolt spacing. Now I am confused as to which flywheel I need. The articles I have read indicate using a small block flywheel. Anyone have an answer?
1955 Chevy 3100
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | the 235 flywheels are different than the later sixes and v8s. i would think you have to use the flywheel and pressure plate at least from the orig engine or maybe have it drilled or machined. maybe a vendor makes one for this conversion. will your t-5 even bolt up to the 235? i didn't think they would w/out a adaptor. might ask where you got the adaptor about the flywheel/clutch combo. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Having the same casting number doesn't always mean that parts will interchange. For instance GMC uses the same casting number on their 6 bolt flywheels, but the ones with a 6 volt ring gear are machined a little different than the ones with a 12 volt ring gear. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Why not use the flywheel out of your 235? That's what I did with my T5 swap. You just need to get a clutch disk to fit the T5 splines. You will love the T5. One of the best things I've done to my truck. George | | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | The issue with the stock flywheel is it only allows for a 9 inch clutch, from what I can determine from research. I was hoping to upgrade to an 11 inch if possible. If you are using a 55-59 stock truck bell housing, there is no need for the spacer according to all the tech tips I have been reading.
1955 Chevy 3100
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The 235 trucks had an option of a heavy duty clutch which is 10 3/4". That is the clutch that is in my truck. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 10"-clutch flywheels are available (if not standard) for later 235/261 engines.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 216, 235 6 volt flywheels came with 9", 10", and 11" sizes. 12 volt came with 10" and 11".
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Well it looks like I am on the hunt for a 11 inch flywheel for my truck. Anyone have an idea of a part number or where to look? Also have a stock 139 tooth, pre 54 along with a good 6 volt starter to swap for the right flywheel. Thanks
1955 Chevy 3100
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Here is a link to the clutch section of the Chevrolet Master Parts Catalog. Page forward and backward to see the part numbers (and some casting numbers) for the various clutch and flywheel that were available in 1957 and earlier. Hope that this helps. I've had no problems with using 10" clutches behind some strong 261s. Hoyt | | |
