| | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 116 | I am wanting to put turn signals on my 55 big bolt. For years, I've had a "new" unit in my garage...one of the clamp-on-the-column style turn signal mechanisms. I just don't have a wiring diagram for it. It's a chromed unit with 7 wires hanging out the back. I'd like to use it. Does anyone have a wiring diagram? Thanks. Jim | | | | | Joined: Jan 2008 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 85 | From what you are saying I think you have a signal-stat model.Try looking at this switch wireing . | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jim, Have you checked out Cletis's signal wiring Tech-Tip? He discusses some 5-wire and 7-wire turn-signal set-ups. Tim | | | | | Joined: Aug 2008 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 116 | I checked my unit during my lunch break. It's a Yankee TurnFlex 730/6. Thanks for showing me Cletis' tips in the Technical Tips section. It is not the same unit, but the method of charting how they work is great! I'll have to try it I guess. | | |
