| | | Forums66 Topics128,110 Posts1,056,257 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | I've got a 1958 235 engine, that I'm just getting into. Went to take the water pump off. 4 bolts came out just fine. Pump won't budge from it's location.
I tapped LIGHTLY with a hammer on the pump housing. No budge. I pryed GENTLY between the block and the pump outlet. No budge.
Any suggestions? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Try a bigger hammer?  You might try using a large punch and a hammer to try to rotate it to break the seal. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | If all the bolts are out, the only thing left is the sealer and gasket. I don't see how you could break anything except the water pump and I'm guessing your replacing it anyway. It just fits in that round hole. Wack it... | | |
