1 members (Oswald), 112 guests, and 0 robots.
Topics128,091
Posts1,056,038
Members48,433
#578416 09/28/2009 2:42 AM
I've got a 1958 235 engine, that I'm just getting into. Went to take the water pump off. 4 bolts came out just fine. Pump won't budge from it's location.
I tapped LIGHTLY with a hammer on the pump housing. No budge. I pryed GENTLY between the block and the pump outlet. No budge.
Any suggestions?
Try a bigger hammer? ohwell You might try using a large punch and a hammer to try to rotate it to break the seal.
V
V Offline
If all the bolts are out, the only thing left is the sealer and gasket. I don't see how you could break anything except the water pump and I'm guessing your replacing it anyway. It just fits in that round hole. Wack it...
