8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 1 New Guy | | New Guy Joined: Sep 2009 Posts: 1 | I have a 216 for my 1951 chevy 3100. I took it to my mechanic after purchase. It was taken out and sent to a machine shop and following planing was peiced back together and ran. I took it out a few times for about a mile or two. I went to pick it up and drive it home when I had a sudden loss of power up a hill and the truck died. The mechanic is now stating that the head has water in it. I would love to know what to do next here should I try to take it back to a machine shop for another look, should I scrap the engine. Any replies are welcome. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The head is supposed to have water in it.
The combustion chamber and the pan should not have water in them.
Did you pay the machine shop to have the head and block checked for cracks/leaks?
Tim
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Who installed the head? Were the head bolts torqued in proper sequence and retorqued? Did you bleed all the air out of the cooling system when you filled it? What was the temp gauge doing when the engine failed? From the little information given, it almost sounds like you had air in the head and it overheated. If that is the case and you drove it until it stopped, there is a good chance you have a cracked head and even possibly a warped block.
Like Tim says, the head is supposed to have water in it. | | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | shea First of all, All heads have water IN them.Second,That the machine shop PIECED IT BACK TOGETHER this leaves many questions that need to be answered but if they did everything correctly-----This is either a head gasket leak or a cracked head. You or mechanic could pressurize the cooling system,AND OR RUN UNTILL you get it hot. Then take out the spark plugs, and crank it over , AND IF ANY WATER COMES OUT OF SPARKPLUG HOLES. REMOVE HEAD and check for flat and true,IF not flat it's POSSIBLE HEAD GASKET, BUT then pressure check or Magnaflux head separate from engine block,this should show any cracks, If cracked it maybe EASIER/CHEAPER to find another head BUT CHECK THAT ONE TO .
| | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | mechanic is now stating that the head has water in it?
he released the vehicle to you as repaired/safe for operation, but now claims no responsibility? | | | | | Joined: Feb 2009 Posts: 49 New Guy | | New Guy Joined: Feb 2009 Posts: 49 | I have a very un-technical term for whatever mechanic has gone and done that, then claimed no responsibility. Not wishing to ignite any hostilities, I'll go with the fact he probably cracked the head. Maybe he means it got cracked up top, and there's water circulating in the oil under the covers? Either way ... that's pretty poor. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think that a basic course in automotive terms and procedures may be the best place for all parties to begin with. Once everyone understands everything then maybe finger pointing can begin. If you are going to own one of these old trucks you really need to understand a few basics, once you do you can be assured that you are getting what you are asking for.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I totally agree don stocker, it is something we need. I recently suggested a Glossery of Terms as a Tech Tip (?) for the uninitiated and newbies. Someone here should write one up and send it in. | | |
