7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 56 | Hey guys,
I got my truck running finally and I realized that i have no idea where the timing amrks are i have looked everywhere i can think of and i have pulled apart the carb and set everything back to where it was and it won't idle i think it has to do with the timing but not sure i don't have any numbers on the block but i know it is a I-6 with the tin plate around the spark plugs any help would be apreciated. | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Sounds like you have a 216 or an early 235. I believe the timing mark is a steel ball pressed into the flywheel but I don't have a truck of that vintage so I'm not positive. Anyone? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | 1 1/2" Hole just above the starter, steel ball in flywheel lined up with the pointer in the hole as Mike discribed. Will help to pull down the pan below the flywheel (4 slotted screws) and clean the timing marks off. DG
Denny G Sandwich, IL
| | | | | Joined: Jul 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 56 | Thanks guys thats really helpful now I might be able to get it to idle, I was told about the block numbers being stamped into the block behind the dist. but I have cleaned it off and I can't seem to find the numbers anywhere, Is there another place I might try to look maybe for casting numbers to help identify what engine I have?
| | | | | Joined: Jul 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 56 | Oh yeah sorry it is a 1942 Chev. but i also don't know of what size the vin tag is missing and the old regi's are hard to read | | |
