3 members (Bill Hanlon, 32Fordpuchoptop, 1 invisible), 103 guests, and 2 robots.
Topics128,049
Posts1,055,635
#578125 09/26/2009 11:29 PM
I'm trying to get my original horn working so I'm trying to figure a way to test the relay. Please correct me if I'm wrong. On my horn relay there are 3 connections, power coming in, a lead to the horn and the third lead to the horn button. The relay functions and the horn blows when the lead to the horn button is connected to ground. Is this right?
If this is correct then when I jump the terminal that goes to horn button directly to ground it should work if the relay is functioning correctly and of course the other connections are in the right spot. Is this correct? Does this make sense?
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Mike,
It's correct and it makes sense. If you have any question about your horn or relay, ground that horn button terminal and tap on the horn and relay with a screwdriver handle...sometimes you need to wake them up.
If the relay is working, grounding that horn button terminal should make a click that you should be able to feel with your hand in the relay.
Stuart
Thanks Stuart. I tried it and "no go". I guess I need a new relay.
Mike
Make sure you have power to the relay and make sure the horn is grounded well.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Yep, I've got power to it and when I run power directly to the horn it's works. Seems to be a bad relay. Napa has 'em for about $10.
Mike
Well, it was a bad relay. I replaced it and that did the trick (Napa $18). I also took off the custom steering wheel that the PO had installed and put on an original and replaced the little italian sports car horn that was on it and installed an original horn. Now it works. All those years of scrounging extra parts sure pays off.
Thanks for all your help.
Mike
Old Gold! Someone paid a lot of money for that custom steering wheel and you just go and change it. Sheesh! You're a lot like me, I guess. I like the old trucks because they were/are a lot of fun (challenge?) to drive. I like mine mostly original, too. WHen I see someone has added those little bitty steering wheels, or bucket seats, Auto transmission, etc, I almost want to cry. But to each his own, and I understand some people want added safety/comfort of disc brakes, power brakes, power steering, etc.
But where's the fun in safety? :-)
(153 Willys pickup, all stock/all original including engine and drivetrain (runs and stops), all original 1959 Apache (runs and stops), mostly all original (has 1949 Pontiac engine in it) 1947 Dodge 1 ton (doesn't run, barely stops). :-)
