| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | I'm trying to get my original horn working so I'm trying to figure a way to test the relay. Please correct me if I'm wrong. On my horn relay there are 3 connections, power coming in, a lead to the horn and the third lead to the horn button. The relay functions and the horn blows when the lead to the horn button is connected to ground. Is this right?
If this is correct then when I jump the terminal that goes to horn button directly to ground it should work if the relay is functioning correctly and of course the other connections are in the right spot. Is this correct? Does this make sense? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mike,
It's correct and it makes sense. If you have any question about your horn or relay, ground that horn button terminal and tap on the horn and relay with a screwdriver handle...sometimes you need to wake them up.
If the relay is working, grounding that horn button terminal should make a click that you should be able to feel with your hand in the relay.
Stuart | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Thanks Stuart. I tried it and "no go". I guess I need a new relay. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Make sure you have power to the relay and make sure the horn is grounded well.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Yep, I've got power to it and when I run power directly to the horn it's works. Seems to be a bad relay. Napa has 'em for about $10. | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Well, it was a bad relay. I replaced it and that did the trick (Napa $18). I also took off the custom steering wheel that the PO had installed and put on an original and replaced the little italian sports car horn that was on it and installed an original horn. Now it works. All those years of scrounging extra parts sure pays off.
Thanks for all your help. | | | | | Joined: Apr 2009 Posts: 10 New Guy | | New Guy Joined: Apr 2009 Posts: 10 | Old Gold! Someone paid a lot of money for that custom steering wheel and you just go and change it. Sheesh! You're a lot like me, I guess. I like the old trucks because they were/are a lot of fun (challenge?) to drive. I like mine mostly original, too. WHen I see someone has added those little bitty steering wheels, or bucket seats, Auto transmission, etc, I almost want to cry. But to each his own, and I understand some people want added safety/comfort of disc brakes, power brakes, power steering, etc. But where's the fun in safety? :-) (153 Willys pickup, all stock/all original including engine and drivetrain (runs and stops), all original 1959 Apache (runs and stops), mostly all original (has 1949 Pontiac engine in it) 1947 Dodge 1 ton (doesn't run, barely stops). :-) | | |
