1 members (1 invisible),
105
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 20 Apprentice | | Apprentice Joined: Nov 2008 Posts: 20 | My '51 1/2 ton stays outside and covered with a tarp to keep the rain off. I am in the process of sanding down my my cab. A few days ago I sprayed the top with Rustoleum Rust Converter to keep it from rusting over. It turned black and I assume that is doing its job of preventing rust from coming back. Is there anything special I have to do to the surface other than maybe using a prep to clean before I apply a 2 k primer? Wasn't sure if the two would be compatible.
JB | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | JB,
I have done as you describe with a similar Rustoleum's and other's rust-converters (sort of a light-brown milky liquid) and PPG DPepoxy primer. So far it has held up fine after 5 years.
Tim
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Read the label on the rust converter on the one I used on the inside of My doors it said You could only use a oil base paint over it so I did not use it anywere I had to paint .
Pete | | |
