0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
Apprentice
Apprentice
My '51 1/2 ton stays outside and covered with a tarp to keep the rain off. I am in the process of sanding down my my cab. A few days ago I sprayed the top with Rustoleum Rust Converter to keep it from rusting over. It turned black and I assume that is doing its job of preventing rust from coming back. Is there anything special I have to do to the surface other than maybe using a prep to clean before I apply a 2 k primer? Wasn't sure if the two would be compatible.
JB
JB,
I have done as you describe with a similar Rustoleum's and other's rust-converters (sort of a light-brown milky liquid) and PPG DPepoxy primer. So far it has held up fine after 5 years.
Tim
Read the label on the rust converter on the one I used on the inside of My doors it said You could only use a oil base paint over it so I did not use it anywere I had to paint .
Pete
