6 members (Gib70, greenie-reddy, Rustnut, Hotrod Lincoln, fonz8261, cmayna), 86 guests, and 3 robots.
Topics128,079
Posts1,056,300
Members48,441
I had an oem one (I think) and it was corroded so badly it could not be salvaged. I found this on ebay, although not the 1960 Model yr. I was wondering if they made one for the 1960-1966 trucks?
http://cgi.ebay.com/ebaymotors/Chev...em255553b3b6&_trksid=p4506.m20.l1116
Ya'll got any sources?
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
didn't they have electric pumps by 60? I had a 62 that was electric, controlled by the wiper switch - the change happened the same time as they quit vacuum wipers as standard
I
I Offline
I have an original foot pump that does not look like that at all. Its got two hoses to it, it gets screwed to the floor through a hole attached to the foot pump. Also the windshield washer bag is original. Its from a 66. Its an air bulb made from rubber.
My '66 had a 12v pump but it went bad.
I found one from a Volvo. Yep thats right Volvo car screws right into the top of the washer bucket like it was made for it, then hooked the 12v from the wiper switch to it and wala! Wash the windshield not a problem... the pump motor is only about the size of a short roll of quarters (2"diameter x 3"tall) sitting on the top, and a hose with the screen goes down into the bottle and the outlet hose goes to your factory windshield wash hoses.
Good luck.
k10 Offline
http://cgi.ebay.com/ebaymotors/Chev...item27abc7bd2c&_trksid=p4506.c0.m245
This is a little closer to a correct accessory. I'm not saying this is it, but it might be a start to getting what you need. It's cheap enough for parts at any rate. I never have seen a foot pump in Chevy or GMC accessory guides for the early 60's trucks.
I picked up one of these on eBay a while back for installation on my '60 GMC. I'll check the p/n for you.
going to hook up my 2 sp. switch and see if get any action on the pump, if not I'll keep looking for a floor model.
Moderated by  ndkid275, Phak1
