| | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I had an oem one (I think) and it was corroded so badly it could not be salvaged. I found this on ebay, although not the 1960 Model yr. I was wondering if they made one for the 1960-1966 trucks? http://cgi.ebay.com/ebaymotors/Chev...em255553b3b6&_trksid=p4506.m20.l1116Ya'll got any sources? Jake
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | didn't they have electric pumps by 60? I had a 62 that was electric, controlled by the wiper switch - the change happened the same time as they quit vacuum wipers as standard
Bill | | | | | Joined: Dec 2007 Posts: 166 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 166 | I have an original foot pump that does not look like that at all. Its got two hoses to it, it gets screwed to the floor through a hole attached to the foot pump. Also the windshield washer bag is original. Its from a 66. Its an air bulb made from rubber.
| | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | My '66 had a 12v pump but it went bad. I found one from a Volvo. Yep thats right Volvo car screws right into the top of the washer bucket like it was made for it, then hooked the 12v from the wiper switch to it and wala! Wash the windshield not a problem... the pump motor is only about the size of a short roll of quarters (2"diameter x 3"tall) sitting on the top, and a hose with the screen goes down into the bottle and the outlet hose goes to your factory windshield wash hoses. Good luck.
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | http://cgi.ebay.com/ebaymotors/Chev...item27abc7bd2c&_trksid=p4506.c0.m245This is a little closer to a correct accessory. I'm not saying this is it, but it might be a start to getting what you need. It's cheap enough for parts at any rate. I never have seen a foot pump in Chevy or GMC accessory guides for the early 60's trucks. I picked up one of these on eBay a while back for installation on my '60 GMC. I'll check the p/n for you. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Thanks going to hook up my 2 sp. switch and see if get any action on the pump, if not I'll keep looking for a floor model. | | |
