| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | Hello everyone,
Just wondering where the dome light switch in a 1941 chevy 1/2 tonne is located and what type of switch it is?
A picture would be great.
Please let me know,
Thanks alot! | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Dome light??? I didn't know these came with a dome light. My 46 dosen't have one. Maybe someone can enlighten me.  I've never seen one. George | | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | Yes sir, there's a dome light over the driver's left shoulder. Just not sure sure where the swicth goes?? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Well, you learn something new everyday. Don't know where the switch goes, but I sure would like to see a pic of your dome light. George | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hmmmm...wonder if this is an after-market item. Don't recall seeing them on any " stock " trucks I have looked at over the years. | | | | | Joined: Jun 2008 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 22 | The 46 I have has a dome light above the driver but I don't know if it was origional, several modifications were done to the wiring over the years. The wiring diagram shows a dome light c/w a switch at the light but indicates "??? Job Only", can't make out the first word. http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm1232.htm | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | Panel Jobs only - the pickups had no dome light from the factory. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Only switched light on my 46, as well as the several trucks 41-46 I've owned is in the center of the dash & it barely glows. Has a little lever/ on off switch, no dome light.
Should be an easy deal to add one from the AD style trucks. | | |
