| | | Forums66 Topics128,004 Posts1,055,265 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | My hi beam headlights go on and off when the truck is ruining can't make it duplicate in the garage when the truck isn't running Is there a breaker or relay on the headlights that might be malfunctioning? | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Bad grounds are always an issue. Make sure you have a good ground wire from your head light buckets to the grounded frame. Do not trust fasteners for your grounds. Otherwise, the hot wire from your lights to your dimmer switch.
| | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | does it happen only when you are driving? or when it is simply running (stationary or moving) It could be a short that only occurs when you hit a bump or something, like a wire getting rubbed through.
Just an idea
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Some of the light switches have breakers on the back of them. If you are running Halegens it might be too much draw for it. If thats the case relays in the system help a lot. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | WRENCH BENDER you might have it. The engine has to be running/ I did install new halogens last year. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I'm under the impression that a fuse or breaker's job is to interrupt current in a either a shorted condition or excessive current load by blowing or opening. Do they not have to be replaced (fuse) or reset (breaker) to restore power to the circuit?
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | A thermal breaker, which is a simple bi-metal contact will cool and self-reset. I believe this is what's on the back of some of the headlight switches.
Stuart | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The AD headlight switch thermal breaker will chatter or buzz with a dead short and the bi metal strip gets really hot. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I have a new switch installed last year. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the switch overload circuit isn't rated high enough for the halogens, do the relay thing - proof would be to put original type bulbs back and watch the problem go away
Bill | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Gazim,
I think I found my problem,you may try it also and see if it helps you. I ran a ground wire from the rear bumper to the bolt that holds the chain for the tailgate( stepside) clamped it on with vise grips, I now have headlights that stay on, I actually sat and watched them for 15 m inutes and they never went out. before within two minutes of turning them on they would be blinking off. I now have to make it permanent. Give it a try and see if it helps.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I kinda doubt it would help me. I have LED tail lights and led's in the box roll also and I grounded them well BUT I do have to do somthing so will try anything. Thanks. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | the switch overload circuit isn't rated high enough for the halogens, do the relay thing - proof would be to put original type bulbs back and watch the problem go away
Bill Thanks Bill, You usually have good answers. I am trying to figure out if I have ever driven the truck at night since I installed the bulbs. Do Halogens use that much more juice?? How come it won't do it unless the motor is running?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 |  maybe vibration of an oxidized connection? maybe even a poor connection at the headlight buckets, like the socket not fitting the bulb spades well - I don't think they draw a huge amount more, but you can't get more light [and resulting heat] without more amps, and ya never know how much those switch overloads can take, especially replacement ones I'd try the old bulbs to see if the problem goes away, then check all the connections in the headlight circuit, might be one that can handle the lower candlepower but heats up with higher Bill | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | LMC has a heavy-duty headlight harness thats suppose to solve the heavy draw problem. Part#36-3580 for 47-57 and 36-3581 for 58-59,price 29.95 plus shipping. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | My truck is a 62, but I will check the catalog | | |
