3 members (60steve, JoeDude, BC59), 112 guests, and 3 robots.
Topics128,203
Posts1,057,286
Members48,467
HEY GUYS,
DOES ANYONE KNOW THE STANDARD SIZE GAS TANK IN A 66 C-20? HAVEN'T HAD A CHANCE TO PURCHASE A MANUAL YET SO A LITTLE UNSURE.
ALSO, SINCE MY FUEL GAUGE DOESN'T WORK, I AM ALWAYS JUST "TOPPING" IT OFF TO MAKE SURE I DON'T END UP ON THE SIDE OF THE ROAD, SO HAVEN'T HAD THE CHANCE TO SEE HOW MUCH IT TAKES TO FILL THE TANK UP FROM EMPTY. ANY INFO WOULD BE APPRECIATED.
SHOULD I JUST ORDER THE NEW SENDING UNIT NOW, OR DIG INTO IT AND SEE IF IT IS SOMETHING SIMPLE LIKE THE FLOAT?
THANKS IN ADVANCE FOR ANY COMMENTS OR INFO.
DOUG
1966 Chevy C-20 Fleetside Longbed
Photobucket pictures
"Better get busy livin' or get busy dying" ~ ...Morgan Freeman
you might do a search on your gauge problem, they are tons of posts in regards to that question
click here, this might help
Redryder pix
My Hotrod
The standard gas tank is about 18 gal.. There was also an optional larger gas tank about 21 gal..
Larry
I don't own a vehicle that isn't old enough to drink.
Standard tank is 18.5 gallons.
A 21 gallon tank was available.
School buses had a 30 gallon tank.
1951 3100 Chevrolet
thanks guys,
I must have the 18.5. It had to be darn near empty one time and it took about 15 gallons.
Not really a "long range" tank now is it?
