9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible), 158 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#575930 09/20/2009 12:22 AM
i'm looking for a new crank for my '54 pressure oiled engine. other then the spash oiled cranks are there any variations in crank design? one that's better than another?
thanks
Earlier ones will not work. 1954-57 are the same. Maybe someone with a newer Master Parts Book will post more information. Is there a "P" forged on the number 5 arm?
Tim
What about a '53 Power Glide Is it the same as the 54 to 57 ?? I may need one also
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
thanks for the link. i didnt know that was on the website.
i dont have the old crankshaft so no way to tell if there was a "P" on it.
to be clear, it is a powerglide, hydrolic lifter engine.
The 29-57 MPB at the link above shows the 53 Powerglide (only) 235 (high pressure) crankshaft as the same as the 54-57 235 crankshaft.
ok. i see that now.
i wonder what the differences are.
i was hoping the cranks would be more universal. this will likely make tracking one down more time consuming.
One of the differences (I think) is that the 53 Powerglide 235 crank and the 54-62 235 cranks are drilled to supply oil to the insert rod-bearings.
Tim
And that is a big difference
that makes sense.
Just got mine yesterday. I had a lot of trouble locating a good price. Local NAPA was not bad. Patricks beat everyone, just decode the year of your 235 block and he can help you. Egge did not have one. By the time I calculated machine shop services plus the cost to secure a used one, you will be within $40.00 or so of a new one. Hope this helps ya!
Hank
1951 restoration on website
http://www.hanklong.com
1953 PG and 1954-62 will all interchange including 261.
My Blog
might beck's have the correct cranks?
http://www.inliners.org/becks/
i'll look into patrick's and becks. thanks for the good leeds.
The factory literature also claims, correctly, that the later cranks are stronger by virtue of using narrower rob journals - which increases the thickness of the counterweight areas.
Here's a diagram of where the crankshaft was beefed up on the 1954 and newer 235s/261s (and, presumably, the 1953 Powerglide 235).
Tim
more good info. thanks.
