2 members (Rusty Rod, LAROKE),
103
Mod | | | Forums66 Topics128,193 Posts1,057,260 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | Hey fellas, I just purchased a heater plate that bolts under my Fenton intake (235cui). Antifreese lines will run to my thermostat housing. I also purchased an adapter for the housing as well. anybody purchase this from Tom langdon Stovebolt?? Just trying to see if anybody had suggestions or problems. Also would like input on any positive performance results. THANKS. J.R. in VA. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I use his on an Offy intake and Fenton exhaust, but just use the hot air from the Fentons,no antifreeze. If I did use antifreeze I'd have to seal up the 2 casting ports on the bottom of the intake because the aluminum plugs they come with aren't water tight. They will leak otherwise. In cold air,I think it helps, but there are others that think differently.
Drew
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Although Tom L. recommends water heat I'm totally with DrewP on using exhaust heat. After nearly 9K on my 235 setup I can verify that it is easier to plumb, provides the necessary heat, and eliminates the potential for leaks which can leave you stranded on the road. The firing order of the 235 insures a pressure differential and unlike coolant heat, the exhaust heat is instantaneous.
Installation of the Fentons to the Offy intake require a bit of grinding on the intake so they fit properly. The heat plate needed to be trimmed a little so the vertical linkage would not scrub. Also, the head of the manifold bolt where the linkage comes up from the bellcrank needed to be ground down a bit for smooth WOT linkage movement. On your Fenton intake I'd bolt them up and see if you could slide a piece of paper between them to insure a good fit for the intake to the head. You might get lucky!!
You might check out my webshots "Shoebox" album for fitment info for the Fenton exhaust heat.
Dave | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I used the coolent method, per Langs advise with good results. No problems at all in about 5,000 miles. I let the truck warm a few minutes thats all, before I take off. Good luck. | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | From the standpoint of driving from dead cold the exhaust wins, and also keeps the oil cleaner (less unburned goes past the rings), you can shut off the choke sooner. The downside is that while water can raise above thermo temperature (and can be set below that by reducing water volume), exhaust heat isn't really regulated except as to how it's designed. I haven't figured out of way of adjusting the gas flow. Any valve will be carboned up quickly (I think), and using an inserted restriction is kind of messy and the size will change with the seasons. | | |
