1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#571953 09/06/2009 8:28 PM
V
Apprentice
Apprentice
V Offline
Does anybody know how to remove the dash from a 65 C-10. I took the three bolts on either end out and it loosened it up, but it feels like its still attached somewhere. Any help is appreciated.
Vooda #571982 09/06/2009 9:59 PM
It's spot welded all along the bottom of the window shield. Depending on your plan you will have cut the spot welds or cut the dash out. Why GM put the three bolts on the ends and then spot welded the rest, I have no idea unless it was for assembly.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #572077 09/07/2009 4:51 AM
i may be wrong but i think he just means the insterment cluster. they have some metal tabs on the inside that the first time makes it a little pain to get out. if you lay in the floor with your head under it you can reach up and pry and work it out, just make sure everything is unhooked. good luck.
hoggyrubber #572353 09/08/2009 2:58 AM
k10 Offline
No, he means the whole dash.
You should remove the windshield and drill out the spot welds. It's a major job, not an unbolt and go type of thing. But it's doable if you're prepared for it.
k10 #572703 09/09/2009 5:11 AM
V
Apprentice
Apprentice
V Offline
Thanks for the info. I didnt ralize it was spotwelded in. Explains why all the beating and pushing I did didn't budge the thing. I think I will just leave it in and do what I need to do that way. Thanks for the info on the instrument cluster as well. I tried to pull it out and had a lot of trouble with it too. It is very helpful to know whats holding you up, so you dont tear something up in the process.
Vooda #572760 09/09/2009 2:24 PM
The inst. clusher is a real bear to remove with those dam* clips where you can't get your hands. I've left blood and skin behind my panel more than once.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Modelman #572925 09/10/2009 2:21 AM
sorry i misunderstood ya. i never thought about taking the dash out.
hoggyrubber #575048 09/17/2009 3:50 AM
V
Apprentice
Apprentice
V Offline
Finally got the instrument cluster out of the truck tonight. That sucked. Chevy builds them so tough you cant even get them apart. Anyway, any ideas on how to clean the haze off the instrument glass. Glass looks good just has a little bit of haze on the outside. Appreciate the help.
Vooda #575094 09/17/2009 5:39 AM
Meguiars, makes a Clear plastic Cleaner and a Polish. It will not remove scratches.
The last time I bought plastic. I picked up some Novus 1,2,3, scratch remover and "Clean and Shine". Haven't given it a good try yet. $2.50 to 4.50 a 2 oz. bottle. www.novuspolish.com
Larry
LGriffin #575422 09/18/2009 9:36 AM
V
Apprentice
Apprentice
V Offline
Thanks, I will get it a try.
