| | | Forums66 Topics128,021 Posts1,055,348 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Does anybody know how to remove the dash from a 65 C-10. I took the three bolts on either end out and it loosened it up, but it feels like its still attached somewhere. Any help is appreciated. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | It's spot welded all along the bottom of the window shield. Depending on your plan you will have cut the spot welds or cut the dash out. Why GM put the three bolts on the ends and then spot welded the rest, I have no idea unless it was for assembly.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i may be wrong but i think he just means the insterment cluster. they have some metal tabs on the inside that the first time makes it a little pain to get out. if you lay in the floor with your head under it you can reach up and pry and work it out, just make sure everything is unhooked. good luck. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | No, he means the whole dash. You should remove the windshield and drill out the spot welds. It's a major job, not an unbolt and go type of thing. But it's doable if you're prepared for it. | | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Thanks for the info. I didnt ralize it was spotwelded in. Explains why all the beating and pushing I did didn't budge the thing. I think I will just leave it in and do what I need to do that way. Thanks for the info on the instrument cluster as well. I tried to pull it out and had a lot of trouble with it too. It is very helpful to know whats holding you up, so you dont tear something up in the process.
| | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | The inst. clusher is a real bear to remove with those dam* clips where you can't get your hands. I've left blood and skin behind my panel more than once. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | sorry i misunderstood ya. i never thought about taking the dash out. | | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Finally got the instrument cluster out of the truck tonight. That sucked. Chevy builds them so tough you cant even get them apart. Anyway, any ideas on how to clean the haze off the instrument glass. Glass looks good just has a little bit of haze on the outside. Appreciate the help. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Meguiars, makes a Clear plastic Cleaner and a Polish. It will not remove scratches. The last time I bought plastic. I picked up some Novus 1,2,3, scratch remover and "Clean and Shine". Haven't given it a good try yet. $2.50 to 4.50 a 2 oz. bottle. www.novuspolish.comLarry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Thanks, I will get it a try. | | |
