4 members (kades51, 1955 1 Series, baldeagle, walter74), 64 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#575187 09/17/2009 5:57 PM
Z
Z Offline
are the only engine mounts for my 1952 truck on the front only? the only other mounts that i see are for the transmission. Am I going crazy?
2000 Nissan Frontier, 3.3L (sold)
2006 Chevy Cobalt SS, 2.4L
1952 Chevy 1/2 pickup, 235 c.i. I6
when life speeds up, downshift
zaboomafoo #575188 09/17/2009 6:01 PM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Nopeeeeeeeeeeeeeeeeeeeeeeee, that's all there is. 2 in front of the motor & 2 at the trans....Joe
#575191 09/17/2009 6:11 PM
Z
Z Offline
thats kinda lame. it looks too weak to me. my neighbor has a 1949 ford truck and he has motor mounts all over the place
zaboomafoo #575192 09/17/2009 6:18 PM
You will find they are more than adequate, not unusual to find 60 year old trucks running on their original mounts. The front mount is the hard one to find parts for the only piece in reproduction is the rubber. The early trucks had horsepower ranges form 90-135 by the time you get to 261's and torque in the 180-200 ranges so they do the job.
Brad Allen #575195 09/17/2009 6:22 PM
And the top cover via Jim Carter.. The bottom metal mount is the hard one to find,I think.
Drew
DrewP #575198 09/17/2009 6:27 PM
Z
Z Offline
hopefully I won't have to replace them. thanks
Brad Allen #575201 09/17/2009 6:28 PM
GMC used the same system. The 2 on the flywheel housing keep the the engine from torquing and the front kept the engine down in front. They were never a problem. The second series in 55 used a strap for a motor mount in front and they broke. I am building a 302 GMC with a 3-2 setup and dual point distributor for a 50 GMC and I will use the stock mount.
crenwelge #575208 09/17/2009 6:37 PM
Z
Z Offline
ok. thanks. it just seems so odd to me bacause im used to modern trucks and front wheel drive cars with trans axles.
zaboomafoo #575412 09/18/2009 6:00 AM
all that is really required is 3 point mounting. 1 at the frt and 1 on each side of the bellhousing. later years it was 1 on each side of the eng and 1 under the rear of the trans
ron
