2 members (moparguy, baldeagle),
84
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 69 New Guy | | New Guy Joined: Sep 2009 Posts: 69 | are the only engine mounts for my 1952 truck on the front only? the only other mounts that i see are for the transmission. Am I going crazy?
2000 Nissan Frontier, 3.3L (sold) 2006 Chevy Cobalt SS, 2.4L 1952 Chevy 1/2 pickup, 235 c.i. I6 when life speeds up, downshift
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Nopeeeeeeeeeeeeeeeeeeeeeeee, that's all there is. 2 in front of the motor & 2 at the trans....Joe | | | | | Joined: Sep 2009 Posts: 69 New Guy | | New Guy Joined: Sep 2009 Posts: 69 | thats kinda lame. it looks too weak to me. my neighbor has a 1949 ford truck and he has motor mounts all over the place
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You will find they are more than adequate, not unusual to find 60 year old trucks running on their original mounts. The front mount is the hard one to find parts for the only piece in reproduction is the rubber. The early trucks had horsepower ranges form 90-135 by the time you get to 261's and torque in the 180-200 ranges so they do the job.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You will find they are more than adequate, not unusual to find 60 year old trucks running on their original mounts. The front mount is the hard one to find parts for the only piece in reproduction is the rubber. And the top cover via Jim Carter.. The bottom metal mount is the hard one to find,I think.
Drew
| | | | | Joined: Sep 2009 Posts: 69 New Guy | | New Guy Joined: Sep 2009 Posts: 69 | hopefully I won't have to replace them. thanks
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | GMC used the same system. The 2 on the flywheel housing keep the the engine from torquing and the front kept the engine down in front. They were never a problem. The second series in 55 used a strap for a motor mount in front and they broke. I am building a 302 GMC with a 3-2 setup and dual point distributor for a 50 GMC and I will use the stock mount. | | | | | Joined: Sep 2009 Posts: 69 New Guy | | New Guy Joined: Sep 2009 Posts: 69 | ok. thanks. it just seems so odd to me bacause im used to modern trucks and front wheel drive cars with trans axles.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | are the only engine mounts for my 1952 truck on the front only? the only other mounts that i see are for the transmission. Am I going crazy? all that is really required is 3 point mounting. 1 at the frt and 1 on each side of the bellhousing. later years it was 1 on each side of the eng and 1 under the rear of the trans ron | | |
