| | | Forums66 Topics128,047 Posts1,055,621 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | sometimes it charges, sometimes it doesn't. that pretty much sums it up. I got a current leak somewhere, battery drains in about 2 days to where it won't start. I have no accessories that use power after I turn the ignition switch off. is converted to alternator (GM 3-wire) still has amp gauge. can anyone give me an idea on how to start looking where it's going wrong? did a quick search and couldn't find anything wrong. did forget to hook up the oil line after checking the back of the gauge panel though. black feet.. oh and it's a 1959.. help is greatly appreciated, it's the daily driver and it needs to run, I need to make $$ with it
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Unhook the 3 wire next time you park it for a few days. See what happens. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | check the brake light to see if it's not staying on. If not that inside the alt. is a diode trio that may be bad and letting power drain away,used to be if vehicle had an idiot lite on dashboard at night it would stay an very dim, you knew diode was bad. I would have someone check the alt and see whats up. Good luck
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2009 Posts: 8 New Guy | | New Guy Joined: Sep 2009 Posts: 8 | here's a tip:
Take the positive side of the battery off. Connect a test light to the battery cable (positive one) and the other end of the test light to the positive terminal on the battery if the light lights up you have something draining.
As mentioned before it could be the diode in the regulator but it may be a faulty ground somewhere also.
Check the wiring till the light goes out rinse and repeat.
When I grease the muffler bearings it always wants to go backwards and the radio plays classical music ... any suggestions?
