3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 7 New Guy | | New Guy Joined: Sep 2009 Posts: 7 | I finally got my 1958 engine out of my 1949 Chevy. Now I need to bolt it to my new engine stand. What size bolts do I need, and does anyone have a picture of what this will look like. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If I remember correctly they would be 7/16" x 14 thread pitch and length according to your type mount. Some people hook the engine stand up with to the clutch housing with the clutch,pressure plate and flywheel removed, but I prefer to bolt the stand right to the back of the block. Mount the rotating head of the engine stand to the block and then hoist the block to hook to the stand itself. A word of caution: Inline 6's because of their length can tip an engine stand very easily,especially the 3 legged stand. A 4 legged stand is better. In any case make sure the block is properly supported as you rotate it or move it around. Good Luck with your project.
Drew
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | Take the flywheel housing off and bolt it directly to the block using the holes where the housing bolted to. Depending on the mounting brackets, you will probably need bolts 1/2" longer then what were used to bolt the housing to the block. Same thread of course. | | | | | Joined: Sep 2009 Posts: 7 New Guy | | New Guy Joined: Sep 2009 Posts: 7 | there are 4 holes, the top two are 7/16 but the bottom two are a different size, before I don't have anything in my garage that fit for example before I run to store? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | On My 52 - 216 they are all the same , take the stock bolt with You to the store and than just get a longer one .
Pete | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | Could be the wrench size is different but the bolt is the same. | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | yes, tipping on a 3 leg. mine makes me very cautious, and when i get it to it's final destination, i use temporary, 2x2 wooden legs to the floor for stabilization. and for some reason, my stand's arm's holes would not accept my block, and after 6 configurations, i drilled extras in-between | | | | | Joined: Sep 2009 Posts: 35 Apprentice | | Apprentice Joined: Sep 2009 Posts: 35 | bwaahahahah... yes this can be a tricky thing to do as I "built" a 250 six for my 67' nissan patrol. it had it's moments when I thought the whole shebang was going to fall over and then I used a lighter weight stand than a heavier one as I did not know better at the time as they can hold different wieghts according to their specific use good luck and be careful!!!!! sdsmooth aka socketdropper. | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I have a 50 year old heavy engine stand. I have seen some real flimsy things out there lately. However, I still bolt a leg to the front of the engine. I have a 3/4 square tube inside a 1" square tube that telescopes and has a set screw with a 18" T welded on one end and a piece of flat with a 3/8" hole on the other end. One bolt in a water pump mounting holes sure stabilizes it a lot. Especially when I am torquing head bolts or main caps. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I have a 50 year old heavy engine stand. I have seen some real flimsy things out there lately. However, I still bolt a leg to the front of the engine. I have a 3/4 square tube inside a 1" square tube that telescopes and has a set screw with a 18" T welded on one end and a piece of flat with a 3/8" hole on the other end. One bolt in a water pump mounting holes sure stabilizes it a lot. Especially when I am torquing head bolts or main caps. That is a clever idea. You should submit it with a schematic or pic to Tech Tips.
Drew
| | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | yes, an excellent idea! i'm puttin the 2xs in the fireplace, and headin to the basement. thanks | | | | | Joined: Sep 2009 Posts: 35 Apprentice | | Apprentice Joined: Sep 2009 Posts: 35 | wow maybe even a patent on it as an accessory item for flimsy stands!!!!!! mine was so bad I had to put the head on after it was in the patrol...... | | |
